I follow you Larry, and I don't know how to get around it with out using the
derived part function. People have told me that I sound like I talk with a
mouth full of marbles. Enunciation is not a strong point of the south I
guess, but we got other things going for us 😉
wrote in message news:4831519@discussion.autodesk.com...
So I take it it's sort'a like I was talk'n with my mouth stuffed with cotton
er someth'n, eh?
I'll try again:
start an ipt,
make a base sketch on the XZ plane (plan view sketch is what I call it)
make a side profile sketch on the XY right profile plane and return,
make another new sketch on a XZ bottom plane and project points etc, from
the preceding profile sketch and draw the bottom profile.
Return and extrude the base sketch.
Extrude the profile sketch.
Intersect the profile extrusion w
ith bottom profile sketch to shape the part.
Now ... instead of having a base plate and a shaped profile part, you just
have a shaped profile part because the intersect took the base plate with
it. So what if you would like to use intersect on about 20 more profiles in
that same ipt ... looks like to me you'd still only end up with the last
profile and all the other ones would be consumed by the 20 intersects ...
although I certainly haven't tried it. I took my queue from the first time
I did it, I think about it every time I want to do stuff it would be useful
for, but never posted it, I'll attach a jpg of one of my forging's to give
you an idea where I think it would e useful.
~Larry
