I read and make the tutorial:
It is written, in the picture, that i ought to find the command Layout Constraint on the right click, but you see on the second picture it isn't.
I also searched other elements for right click, but didn't find
This is what I see using your files
First step -
reboot your computer and check again.
Karol,
According to this thread there is a fix for this coming out in update 2 for 2014.
Assuming you are using 2014.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
@Cadmanto wrote:
Karol,
Uhmm, Update 2 has been out for some time.
Maybe that is why it worked for me.
Maybe, strong possiblility!!!
Until Karol goes under the "About Inventor" in the help drop down to varify whether he has this update or not, anything said here is kind of moot.
