I'm getting a Resolve link screen when I open an assembly but the part it needs doesn't even exist in the assembly.
Is there a way to remove this link, so I don't get the screen everytime I open the assembly.
Thanks in advance!
Solved by japike. Go to Solution.
The resolve link dialog is saying that part 099.99.00.001.ipt has a reference to 002.31.00.002.ipt that is can't find in the current project paths. You could add a path in your project file to the part or break the link in 099.99.00.001.ipt.
Leander,
Just went through this yesterday.
Take a look at my thread and see if it helps you.
http://forums.autodesk.com/t5/Autodesk-Inventor/UnResolved-Files-in-an-Assembly/td-p/3808936
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thanks, I think I just overlooked it.
099.99.00.001.ipt indeed still contained a link with the 002.31 file, thought I fixed all the parts, missed this one I guess.
Thanks!
Cad, that only works with an assembly, my problem was deeper in an part.
