I can't get into online (or local) help
This is the message I get when I click on Inventor "?" Other Autodesk products have no problem, only Inventor (both 2015 & 2014)
PDSU 2015
Windows 7 Home Premium
16 GB RAM
Julian
Hi JGR44,
Have a look at these links:
2014
2015
http://knowledge.autodesk.com/sites/default/files/file_downloads/Install%20Local%20Help.htm
I hope this helps.
Curtis
Thanks Curtis
- I've downloaded and installed local help
- In Application options - General set to Local help
- Still no Help
Julian
PDSU 2015 (2014)
Windows 7- 64 bit Home premium
16 GB RAM
Hi JGR44,
I don't have any other suggestions, but I did find this related, but unresolved post:
http://forums.autodesk.com/t5/Inventor-General/2014-error/td-p/3934218
I hope this helps.
Curtis
Is this a fresh install? If so, did you follow the AutoDesk Software Installation Guide? If not, then what changed since the help was last working? Any network infrastructure changes, new software, etc.?
Thanks Curtis and Mike.
I think the problem is in my system. This error came up after I've downloaded and installed 2015 AutoCAD (vanilla), Alias Design, and Showcase, modules that were not included in the original 2015 PDSU package, previously installed. (I've followed the installation instructions)
The strange thing is that only Inventor has this Help problem not AutoCad plain or Mechanical etc.
Autodesk might have some explanation.
Anyway I'll get my IT gurus to have a look at it.
Thanks again
Julian
I've installed them in order as they were listed in the Adesk Download page:
1-AutoCAD, 2-Alias, 3-Showcase
Julian
