Inventor Forum
New Inventor session opens when I open a new drawing
17 REPLIES 17
Message 1 of 18
ChrisBorthwick
1470 Views, 17 Replies
Every time I open a new drawing a new Inventor session starts up and the drawing is opened in there. It's ok if I go through file-open etc in a current Inventor session but I don't want to open drawings like that all the time. If I open 5 drawings at once they start up in 5 seperate Inventor sessions! I can't seem to find an option to change this, is it an inventor problem or windows?
Thanks!
17 REPLIES 17
Message 2 of 18
scottph
in reply to: ChrisBorthwick
It does not work like that for me, all documents open in the running session.  So I asked around and the only suggestion I could get is to use the task manager to kill all Inventor and explorer sessions.  Restart explorer, then restart Inventor.  Inventor registers with explorer, and it might prompt a re-registration.
This might not help, but it's all I could come up with.  If I get anything else I'll let you know, though.
Message 3 of 18
Hi ChrisBorthwick,
It might help to tell others the version of Inventor and Windows you're using.
example:
Inventor 2013 - Service Pack 1.1
Windows 7 - Service Pack 1
I hope this helps.
Curtis
Message 4 of 18
blair
The proper methodolgy is to start Inventor first, make sure that you are using the correct Project file, then select New and then the required drawing template.
It sounds like you are doing something else such as using Windows Explorer to navigate to where your drawing template is stored. If this is the case, then a new version of Inventor will open.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 5 of 18
t_fransman
in reply to: blair
Seems to be a new behavior in 2020, and it's really annoying. Would open from the double click in previous versions of Inventor all day in same session. Have been using inventor for 15 + years this is a new annoyance. The issue for me isn't opening a "new" drawing it's opening everything In double click in new sessions. Existing things. things I need to copy and paste leader text from etc. ..
Message 6 of 18
mcgyvr
in reply to: t_fransman
@t_fransman  Not a new intended behavior.. My 2020 opens files from explorer in the same session/instance..
Have you tried this https://knowledge.autodesk.com/support/inventor/learn-explore/caas/sfdcarticles/sfdcarticles/Opening...
Thats for ipt files.. If drawings aren't working correctly just adjust for idw files (or Inventor.DrawingDocument if looking at the registry settings)
Message 7 of 18
t_fransman
in reply to: mcgyvr
it is new for us here and pretty much across the board. Never had the issue before. The r click open with thing creates a duplicate entry. We tried that to get it to stop opening in read only mode all the time first. That was also annoying. See jpg attached/
Message 8 of 18
t_fransman
ddeexec Data [open("%1")] was set for all across the board. I think it has to do with the new read/only mode. Because I had to do a open with to get it not to open everything in read only mode for most users. And now it has multiple instances under open with.
Message 9 of 18
mcgyvr
@t_fransman  Have you loaded all updates for Inventor 2020?
You can clear out the OpenWith by going here and removing the duplicates from the registry editor..
\HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.idw\OpenWithList
Message 10 of 18
t_fransman
in reply to: mcgyvr
yes all users have all current updates. May need more instructions on dup entries for the regedit. if possible.
Message 11 of 18
mcgyvr
@t_fransman
Open rgedit
Go to this location \HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.idw\OpenWithList
Delete all keys where the value data is "Inventor.exe". (heck you can delete any a,b,c,d,e.... keys)
Close regedit
repeat the "Open With" process to set the correct "Inventor.exe" program and select "always open with"
Should look like this when done basically..
Message 12 of 18
t_fransman
in reply to: mcgyvr
We tried this and the "open with" r click menu persists even after a re-boot to have two instances. ugh
Message 13 of 18
mcgyvr
@t_fransman  Show me an image of your registry settings just like I posted.
You are making the registry delete/change for "idw" files and looking at the right click menu for an idw file right?
Message 14 of 18
johnsonshiue
Hi! This behavior may not be dictated by application like Inventor. It is somewhat if not totally, by Windows. This has something to do with "dde" or "ddeexec."
Here is what I found. Launch Regedit.exe and go to the following keys.
Computer\HKEY_CLASSES_ROOT\Inventor.PartDocument\shell\open\command
Default = "C:\PROGRA~1\Autodesk\IN2AA9~1\Bin\Inventor.exe /dde"     (make sure double quotes are removed)
Computer\HKEY_CLASSES_ROOT\Inventor.PartDocument\shell\open\ddeexec
Default = "[open("%1")]"                         (make sure double quotes outside of the brackets are removed)
You will need to also check "Inventor.AssemblyDocument" and "Inventor.DrawingDocument" additionally.
Try it out and see if it works.
Many thanks!
Software Test Engineer
Message 15 of 18
t_fransman
in reply to: johnsonshiue
Thanks, Johnson Shiue
But those settings are things I've already verified. The problem still persists on several of our work stations. Any other ideas??? Also I made an error I am using 2021 windows 10 and all available update are installed. My mistake.
Message 16 of 18
johnsonshiue
Hi! I am sorry I am running out of ideas also. Try something and see if it helps.
1) Right-click on the Inventor 2021 desktop icon -> Properties -> Compatibility -> check "Run as Admin."
2) Start Inventor.
3) Close Inventor and uncheck the option on Step1.
Many thanks!
Message 17 of 18
t_fransman
johnsonshiue
nope didn't work. Ugh
Message 18 of 18
t_fransman
in reply to: mcgyvr
Yes i tried that. I then figured out if you go "open with" when it's doing it wrong. Ya just have duplicates of the program in the "open with" you kill those it fixes it unless you use view in window, which i liked the Inventor light view only thing however, this problem makes me not want to use it because as soon as i do it creates a multiple instance in " open with" and always uses the new instance. So I don't view in window anymore, problem solved ( sort of ugh ) >?
