Inventor Forum
New Error: "The handle is invalid"
2 REPLIES 2
322 Views, 2 Replies
For various reasons (thank you Mr. Gates) I had to reinstall the operating system (Windows XP). I started with an fdisk and proceeded installing windows xp with all service packs. I then went about installing the rest of the programs I use on a regular basis including R8 SP1. When I attempted to open a file I got the following error: "The handle is invalid". In our office we have reinstalled the operating system on several systems and never seen this error. The hardware is a 2Ghz AMD 2600 running on 1.25gb RAM. Assuming a bad install I went down the path of fdisk, formatting and installing the operating system again, still the same problem. Any ideas would be much appreciated.....
2 REPLIES 2
so, you can start Invenyor fine but you can't open ANY R8 file? not even the samples that come with IV? What about a new file? K "Jim Tippett" wrote in message news:40fd8868$1_2@newsprd01... > For various reasons (thank you Mr. Gates) I had to reinstall the operating > system (Windows XP). I started with an fdisk and proceeded installing > windows xp with all service packs. I then went about installing the rest of > the programs I use on a regular basis including R8 SP1. When I attempted to > open a file I got the following error: "The handle is invalid". In our > office we have reinstalled the operating system on several systems and never > seen this error. The hardware is a 2Ghz AMD 2600 running on 1.25gb RAM. > Assuming a bad install I went down the path of fdisk, formatting and > installing the operating system again, still the same problem. Any ideas > would be much appreciated..... > >
Did you ever find a solution to this problem - or find out what was causing it.
I currently have the same problem and need to fix it asap!
Regards
Danny
