I have a quiet complex .iam that i need to make the same, but bigger, not in a exact scale, but something like *1,37, could someone help me?
Olá,
Eu tenho uma montagem um pouco complexa, e preciso reproduzi-la em escala maior, porém não é uma escala exata, alguém sabe alguma forma de me ajudar?
Att.
Gabriel
If everything is uniformly scaled you can use Derived Components to do this.
The CADWhisperer YouTube Channel
as an alternative beside "derived-part" method. you can use skeleton modelling to make all component ( ipt ), and multiplying all parameter with scale you want to use.
create an ilogic to control this scale from main assembly.
