I have a quiet complex .iam that i need to make the same, but bigger, not in a exact scale, but something like *1,37, could someone help me?
Olá,
Eu tenho uma montagem um pouco complexa, e preciso reproduzi-la em escala maior, porém não é uma escala exata, alguém sabe alguma forma de me ajudar?
Att.
Gabriel
If everything is uniformly scaled you can use Derived Components to do this.
as an alternative beside "derived-part" method. you can use skeleton modelling to make all component ( ipt ), and multiplying all parameter with scale you want to use.
create an ilogic to control this scale from main assembly.
