I was given the following part, and I need help completing it. I am totally out of my league with this one:
The radius' of the bend are all different. The part has a twist.
I'm pulling my hair out here (what's left of it).
I'm using Inventor Standard 2014.
I would appreciate any effort.
Solved by WHolzwarth. Go to Solution.
Solved by JDMather. Go to Solution.
Assuming you are looking to do nothing more then fill the void around the bend?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I didn't take the time to make perfect.
Well, now I can't add attachments?
Ok, got it with a different browser.
The CADWhisperer YouTube Channel
Thank you Professor Mather.
Can I assume, since it was a step file, that you used another program to complete the bends?
and, Btw, what browser did or didn't work?
I appreciate this forum and all of those who assist newbies like me.
I know this part isn't perfect, but this is how far I got until I saw that JD beat me to the punch.
I think you can see I had a couple of profiles and guide curves that I was bringing together.
Anyway, maybe it will help you ultimately.
No problem. Is this part imported from Solidworks? I ask, because I have SW 2011 that I could try it in.
I used only Autodesk Inventor, but thought my quick and dirty "solution" was a little rough - so didn't want to post my dirty laundry here.
Frankly - if it were my part I would use this file to remodel the part correctly from scratch.
Here's my approach. It took some time, finding the best way.
Walter
Walter Holzwarth
Hi, there,
I tried by loft and looks simple, but may not what you want. You need sheet metal, right!
RGD!
