Inventor Forum
Need assistance completing partial part
14 REPLIES 14
Message 1 of 15
Davarn-Tool&Die
529 Views, 14 Replies
I was given the following part, and I need help completing it. I am totally out of my league with this one:
The radius' of the bend are all different. The part has a twist.
I'm pulling my hair out here (what's left of it).
I'm using Inventor Standard 2014.
I would appreciate any effort.
14 REPLIES 14
Message 2 of 15
Cadmanto
in reply to: Davarn-Tool&Die
Assuming you are looking to do nothing more then fill the void around the bend?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 15
Davarn-Tool&Die
in reply to: Cadmanto
Yes. the radii pretty much completes the part.
Message 4 of 15
JDMather
I didn't take the time to make perfect.
Well, now I can't add attachments?
Ok, got it with a different browser.
Message 5 of 15
Davarn-Tool&Die
in reply to: JDMather
My email is darnold at mcstamp dot com
Message 6 of 15
Davarn-Tool&Die
Thank you Professor Mather.
Can I assume, since it was a step file, that you used another program to complete the bends?
and, Btw, what browser did or didn't work?
I appreciate this forum and all of those who assist newbies like me.
Message 7 of 15
Cadmanto
I know this part isn't perfect, but this is how far I got until I saw that JD beat me to the punch.  Smiley Happy
I think you can see I had a couple of profiles and guide curves that I was bringing together.
Anyway, maybe it will help you ultimately.
Best Regards,
Scott McFadden
Message 8 of 15
Davarn-Tool&Die
Thank you as well, Scott. I couldn't get the sweeps to line up either. I had someone try using Solidworks with the Logopress add in and he could get it either. Eph. 2:7
Message 9 of 15
Cadmanto
No problem.  Is this part imported from Solidworks?  I ask, because I have SW 2011 that I could try it in.
Best Regards,
Scott McFadden
Message 10 of 15
JDMather
I used only Autodesk Inventor, but thought my quick and dirty "solution" was a little rough - so didn't want to post my dirty laundry here.
Frankly - if it were my part I would use this file to remodel the part correctly from scratch.
Message 11 of 15
Davarn-Tool&Die
It has a long history. Began life as an NX unigraphics file. Imported into Inventor for modification to width and length. Then given to Solidworks Logopress.2014 to bend from 90° to 87°. That only partially worked.
The part Professor Mather did will work for this prototype part.
Thanks again.
Message 12 of 15
Here's my approach. It took some time, finding the best way.
Walter
Walter Holzwarth
Message 13 of 15
Nice!
Thank you, WH!
Super Kudos!
Message 14 of 15
Hi, there,
I tried by loft and looks simple, but may not what you want. You need sheet metal, right!
RGD!
Message 15 of 15
or as attached if you want to tangent joint.
Autodesk Customer Advisory Groups
