Inventor Forum
Need Help Badly
7 REPLIES 7
Message 1 of 8
934 Views, 7 Replies
Need Help Badly
First of all, I apologize if this is in the wrong forums section, I didn't really know where to post it. So, I have an assignment due by the end of this week and I need inventor to do it, however, I keep getting errors all around, and I have no clue how to fix them.
In Application Options I ran a diagnostics test and recieved the error:
This Direct3D graphics driver is not Microsoft WHQL certified
Graphics Hardware Description:
Intel Corporation Intel(R) HD Graphics Family
AIRViz Device Manager \ VirtualDeviceDx11
Feature Level 4_5
Performance Mode
Hardware Renderer
Graphics driver file igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32 is version 8.15.10.2353
Current optimization settings are not known
The display is using 32-bit color
Inventor Version:
Build: 170, Release: 2014 RTM - Date: Thu 02/28/2013
64-Bit Edition - 8192.00 GB
System Information:
Operating System: 		64-bit Microsoft Windows 7 Ultimate  (Build 7601) Service Pack 1
Language: 			English
System Manufacturer: 		Gateway
System Model: 			DX4860
BIOS: 				BIOS Date: 08/01/11 14:16:44 Ver: 04.06.04
Processor: 			Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz (1 processor, 2 physical cores, 4 logical cores)
System Memory: 			5.907 GB RAM
Graphics Device Information:
Renderer: 			HAL
Manufacturer: 			Intel Corporation
Chip Type: 			Intel(R) HD Graphics Family
DAC Type: 			Internal
Graphics HW Memory: 		64 MB
Display Mode: 			1920 x 1080 (32 bit) (59 Hz)
Graphics driver file: 		igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32
Driver file version: 		8.15.10.2353
Driver Date: 			4 April 2011 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description: 		Intel(R) HD Graphics Family
Vendor ID string: 		0x00008086
Device ID string: 		0x00000102
VendorID: 			8086
DeviceID: 			102
SubSystemID: 			5891025
Revision: 			9
Direct3D 10 / DXGI System Information:
Dedicated Video Memory: 	64 MB
Dedicated System Memory: 	0 MB
Shared System Memory: 		1.594 GB
DxDiag System Information:
Operating System: 		Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: 			English (Regional Setting: English)
Processor: 			Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz (4 CPUs), ~3.3GHz
System Memory: 			6144MB RAM
Page File: 			5351MB used, 6743MB available
DirectX Version: 		DirectX 11
DxDiag Version: 		6.01.7601.17514
DxDiag Graphics Device Information:
DirectX Version: 		10.0
DDI Version: 			unknown
DDI Version Number: 		0
DxDiag WHQL Level: 		0
Driver Signed Valid: 		True
Driver Signed: 			True
DAC Type: 			Internal
Revision:
Graphics HW Memory: 		1696 MB
Display Mode: 			1920 x 1080 (32 bit) (59Hz)
Graphics driver file: 		igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver file version: 		8.15.0010.2353
Driver Date: 			10/31/2013 10:28:30
WHQL Level: 			0
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Graphics driver log information:
 and whenever I try to create something all I see is just a gray screen, however whenever I go to create a sketch or something the image just gets basically dragged all around the place. I'll attach a screenshot to better explain that.
Thank you very much in advance.
7 REPLIES 7
Message 2 of 8
mdavis22569
I didn't read the entire report you posted ...
you're going to have to play with your graphic setting. What kind of card are you using?
Mike Davis
Message 3 of 8
JDMather
Have you installed latest driver for that graphics card?
Have you installed all Service Packs and Updates for your version of Inventor (2014 has 1SP and Update 2 for SP1)?
Try going to Tools>Application Options>Hardware tab and set to lowest setting.
Message 4 of 8
I have the latest drivers and all, but no, I do not have the Service Packs. Should I try and download those?
Message 5 of 8
JDMather
http://usa.autodesk.com/adsk/servlet/ps/dl/index?linkID=9242019&id=2334435&siteID=123112#section15
Message 6 of 8
Cadmanto
Josh,
You absolutely should have the latest SP loaded.  By doing this it eliminates this from being the issue.
Also, you say you have the latest video driver loaded, yet in your initial posting the driver date shown is this
Are you saying the latest driver is nearly three years old?  I really find that hard to believe given that electronics update on a monthky basis.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 7 of 8
rhasell
Looks like a graphics card issue.
Can you post more information on your hardware?
Looking at your log file, there are 2 cards running. I am making the asumption there is an internal and an add-on card?
 IF SO,  then try and disable the internal card in the system BIOS, this should solve the issue. (There is a driver version/date  discrepansy - 2011/2013 driver version)
Reg
2025.1.1
Please Accept as a solution / Kudos
Message 8 of 8
sam_m
in reply to: rhasell
2nd card?  All I can see (on a quick scan) is the Intel HD gpu incorporated in the i3-2120 cpu.  (it's a Intel HD 2000 gpu, DirectX 10.1 from memory)
is there a dedicated graphics card in the pc at all?  If not then I guess that's the 1st problem...  Plus, 6GB ram isn't that great for Inventor and it could stuggle with anything but the simplest parts.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
