I think it's because you haven't defined a path for the library files. If
you go to the main screen of the content and choose configure then edit and
select Parent Assembly it seems to ask you for a place to store (and how to
name the file). If you choose Workspace it places it in your workspace by
default. Or you can choose a defined Library path...
Well no, there blows that theory Now it's not asking.. I'm not sure. I
can get it to happen sometimes but not others. Just another reason to use
iParts I guess
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
Tampa Bay is going to spank the 49ers...
"Nick Ruberg" wrote in message
news:0436747E7815C61AFE1864B7CD1234E1@in.WebX.maYIadrTaRb...
> This is an IV6 library part, under standard parts, DIN, Circlips, DIN 472
> (The one I used was 24mm, but that should not make a difference). The
term
> drawing was indeed misleading, I obviously insert it into my assembly
(with
> the idrop tool).
> Nick
> "Sean Dotson" wrote in message
> news:A71447B8F84811CC630136EB2A986F62@in.WebX.maYIadrTaRb...
> > Is this an ipart, an IV content part or just a part that exists in the
> > library. I'm not following you exactly. You say
> > "DIN 472 internal circlip and it asked me for the part number before
> > inserting it into the drawing"
> > By drawing do you mean and IDW or do you mean an assembly (IAM)?
> > Sean Dotson, PE
> > news:F59292B40320ACA2D17F735CA3031575@in.WebX.maYIadrTaRb...
> > > I normally place library parts into my assys and then rename the part
to
> > > coincide with our company's part number for that item. I have just
> placed
> > a
> > > inserting it into the drawing. Can I make the library parts do this
> with
> > > everything?
> > > Thanks,
> > > Nick
