After adding the material column did you right click on the name and tell it to show
materials? Are you sure about your spelling and upper and lower case on the material
names. They have to match perfectly.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"T_Graziani" wrote in message
news:f14d174.-1@WebX.maYIadrTaRb...
> I'm creating a new ipart factory. No matter what I put in the material column, the ipart
products always have the same material that I originally set. I've seen cbliss iParts that
allow you to switch between materials, why won't mine work?
> Tony
