Hello, I am trying to model a kayak paddle to make a mold to lay-up my own fiberglass blade. I successfully modeled the blade I want and now need to extend the surface to make a smooth curve for the molds.
1.) If there is a better way to do this besides making the surface model of the paddle, making a flat, large surface, and patching the two I would like to know that.
2.) I am receiving errors when trying to thicken the surface.
The error I get is "The thicken operation did not produce meaningful results.
Thank you,
Kevin
Can you attach the original file here rather than a Derived Component?
I sure can, it is attached below. I modeled the part in inches in the mm dimensions. I have not been able to find a way to switch the units to mm without converting the numbers as well. This was the best solution I could find among the forums.
You can either type in units as you go
or
Tools>Document Settings>Units set the units you want to use at the start
or
start from the appropriate template for the units you intend to use.
I think you have made this a more complex part that it really is (if I add one more dimension it is up to d501).
I recommend that you start over from scratch (with correct units) using what you learned from this first attempt to simplify the effort.
(For example: Loftsrf13 is (or should be) a simple trimmed planar surface.)
Edit: Looked at it a bit more - I think it can be done with 5 or 6 simple sketches. Maybe 1 or 2 user created Work Planes.
Do you have some original artwork or image you are working from?
Top, front, right, pictures of an actual object?
Edit 2: I recommend that you forget about the mold for now and simply model the finished paddle.
So the truth is there is not a way to fix the easy mistake of starting in incorrect units in inventor, just to start over.
Also there is not a way to combine surfaces either?
SMH
I appreciate your help, I'll try starting over.
