How to set multi parameter, iproperty using ilogic (or smth else)?
I hav eparameters: d1=50, d2=100, d3=5. I need to set a new multi parameter/iproperty that the final value is:
Angle 50x100x5 (suppousedly code should contain smth like: "Angle", "d1", "x", "d2", "x", "d3") but I do not know exactly... ;(
Please Help!
parameters:
d1=50
d2=100
d3=5
make a parameter called "angle" in de parameter window and just make it equal to the code below. Then you will have a parameter called angle and it is calculated with d1*d2*d3.
angle=d1*d2*d3
or if you mean you want an string value of angle = 50x100x5
you can do it like this, make a string parameter and then add this in a ilogic rule.
sParameter= "angle" & "x" & d1 & "x" & d2 & "x" & d3
