When using move face, if I use the direction and distance option and then later edit the feature, the original distance used is shown in the box and is ready for editing.
But, when I use the manipulator option and type in a distance, when I later edit feature the original distance entered is reset to zero, so there is no record of what the original distance was.
Is this how its meant to work?
Sounds like as designed to me.
The direction and distance option, only does one thing and produces a single number as result.
So it is easy to bring back that number during edit.
The "manipulator" option that you refer to is what I would call the "Free move" option.
This option is more complex and gives you the power to do a succession of multiple translations and rotations.
How do you expect us to remember all these values also considering that they can be entered in multiple mini-toolbar dialogs?
Bob
@bobvdd wrote:.
Bob
The mini tool bar dialogs update as you drag so there is code keeping track of the movement direction. So you could declare six variables representing the total move in each direction and in the code for each drag event you could sum them up
Total move x = total move x + increment x
Total move y = total move y + increment y
etc
and then recall the six totals next time the feature is edited.
