Dear ,
Curtis_Waguespack
More information is needed.
The location and distance between pivot points is needed.
Is the load along the entire length of the cantilever or is it at the end of the cantilever?
Can you attach the assembly here?
I was going to give this as an assignment to my class - but we need more information.
Hi mech_royalabhi,
I just noticed this post. As JDMather mentioned there are a lot of details needed still in order for someone to help you with this. Attaching your assembly would likely be the best bet.
I hope this helps.
Curtis
Hey all,
Have got a solution for your question?
For a comparable mechanisme with several hinges / levers I try to discover the forces of 2 hydraulic cylinders in the mechanisme to get a mechanical balance for a certain unbalance at the end of the construction.
The model is made with derived blocks.
The model is constrained and can only make the realistic movements.
Now the cylinders are modelled as as a single line, but not constrained at both ends with a point-point constrain to the rotating points,
One end is a point-point and the other end is a point-line constrain to keep the model flexible.
How to get answers from the model for the resulting forces of the cylinders to get a balanced model?
Thanks in advance
