Inventor Forum
Mold Base (not responding)
3 REPLIES 3
sheriff12
311 Views, 3 Replies
I am working in the Tooling tutorials for Inventor 2014. When I try to generate the Mold Base for either a Two-Plate or a Three-Plate the dialog box says (not responding). I have given the program ample time to recover, but it doesn't. I tried to start both tutorials from the beginning on a number of occasions, but I always get the same results (not responding). I followed all the prerequisites for the tutorials. Does anyone have a solution? Thanks!
3 REPLIES 3
JDMather
in reply to: sheriff12
Have you installed Service Pack 1?
Close your files.
Go to your active Project file and click this button.
Do you see any Mold libraries loaded (You will have to download the content shown red here - if you need it).
You do not have to be running Vault if you have the content loaded locally.
The CADWhisperer YouTube Channel
sheriff12
in reply to: JDMather
The Inventor Mold Metric Library is installed properly. The In Use box is checked. It is set to Read Only.
JDMather
Can you attach the assembly here?
