Inventor General Discussion
*Expert Elite*
JDMather
Message 11 of 17 (257 Views)
Re: Modelling Leather Coverings
08-23-2012 01:54 PM in reply to: VictorBDEngineer
VictorBDEngineer wrote:
... The default settings were giving me notched edges for the folds which would not be appropriate for leather.
Unless your parts resemble sheet metal parts (bent planar faces, (and maybe cylinders and cones), forget sheet metal tools.
You might be able to use one of the 3rd party unfolders with Inventor using the standard tools to create your models.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
VictorBDEngineer
Message 12 of 17 (246 Views)
08-23-2012 07:04 PM in reply to: jletcher
Thanks for the offer. I have attached a zip file of the assembly I want to cover. The leather should cover the foam block and be pinned to the body support top sides.
Not sure this is going to help me learn how to do this myself.
Thanks anyway
Victor
Active Contributor
VictorBDEngineer
Message 13 of 17 (245 Views)
08-23-2012 07:06 PM in reply to: JDMather
What 3rd party unfolders are there out there?
*Pro
jletcher
Message 14 of 17 (229 Views)
08-24-2012 04:15 AM in reply to: VictorBDEngineer
The best is SPI it will unfold anything as mention in early post. I have used it to do heli body parts and we all know how nicely shaped they are and it flatten everthng I had Here is a pic of the heli.. It's a V-22.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
*Expert Elite*
JDMather
Message 15 of 17 (225 Views)
08-24-2012 04:20 AM in reply to: VictorBDEngineer
Victor
Inventor preserves the history of the steps needed to create parts.
By examining the steps you can learn how to use the software.
Nearly everything I know about Inventor was learned by examining solutions posted here.
First thing I noticed is that your Sketch1 is not constrained or making use of obvious symmetry about the origin.
Second I noticed that you used Adaptivity (I would not recommend this technique until you gain more experience).
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
then through a step-by-step process we can work towards a solution to the problem.
*Pro
jletcher
Message 16 of 17 (221 Views)
08-24-2012 04:26 AM in reply to: VictorBDEngineer
Don't have 2013 loaded so files I cannot open. I have 2013 just not going to load it.
Thats what the end of part shows just roll it up and drop down feature by feature this will help you learn what people did to make the part.
James Letcher
Active Contributor
cbell1007
Message 17 of 17 (151 Views)
02-08-2013 10:56 AM in reply to: VictorBDEngineer
I design cushions for airplane seats and am trying to display a leather cover on the cushions with pull lines for piping detailing. etc. I am also wondering if a leather material style is availble for DL online.
Announcements
Need installation help?
