Inventor Forum
Modeled threads
4 REPLIES 4
tmccar
340 Views, 4 Replies
Modeled threads
Does Inventor actually model threads? That is, would it produce a usable male or female thread if 3D printed?
4 REPLIES 4
Curtis_Waguespack
in reply to: tmccar
Hi tmccar,
I think this Exchange App add-in is currently the best way to do this:
http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=autodesk.appstore.exchange.autodesk.com...
I hope this helps.
Curtis
CCarreiras
in reply to: tmccar
Hi!
Yes. You can use coil  tool
or sweep tool + helical curve (3d Sketch).
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
tmccar
in reply to: Curtis_Waguespack
Thanks - does this work in LT also?
Paul-Mason
in reply to: tmccar
The problems I found with the using the coil is the the sketch had to be slightly smaller than that actual book pitch of the tread or I got an overlapping error, as well as that it can sometimes be difficult to correctly align the threads in an assembly even when there created on the same plane.
Other wise this method give a an excellent modeled/cut thread.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
