"Andrew Pawelski" <
href="mailto:andrew.pawelski@valiantREMOVEmachineTHIS.com">andrew.pawelski@valiantREMOVEmachineTH...>
wrote in message
href="news:51528E0C3C683818090888CB9A9E0012@in.WebX.maYIadrTaRb">news:51528E0C3C683818090888CB9A9......
Sean,
On their webpage, under file formats, you'll
notice that it says "IAM, IPT (may require additional download)."
On the ModelPress Publisher download page
you'll notice "Autodesk Apprentice 6.0
size=1>(required to publish Inventor files)
size=2>". I'm currently downloading
this 32MB file, hopefully this will enable it.
Andrew
"Sean Dotson" <sean at sdotson dot com>> see my
wrote in message
href="news:330534373C62203358C0ED4D56C432F2@in.WebX.maYIadrTaRb">
face=Verdana
size=2>news:3...
face=Verdana size=2>...
reply to the thread:
> Viewer for Inventor- ModelPress
Announcement
> "Can anyone else get this to
work?
> Apparently their press release beat the updating of the software
as when I
> try to export any files it creates 0 files (even though it
appears to be
> crunching away)"
> Sean
Dotson, PE
size=2>http://www.sdotson.com
Check the Inventor FAQ for most common questions
href="http://www.sdotson.com/faq.html">
size=2>www.sdotson.com/faq.html
> "Ltspd" <
face=Verdana size=2>ltspd@charter.net>
wrote in message
href="news:E8075D6464061119CC139EAF4A3930C2@in.WebX.maYIadrTaRb">
face=Verdana
size=2>news:E...
> > Just to let everyone know, I received a
email from
face=Verdana size=2>http://www.modelpress.com/
size=2> and they now support R6 of IV.
> > Good View,
easy to use from my experience with R5.3
"Sean Dotson" <sean at sdotson dot com> wrote in message
href="news:C94510C3B091446A47DD64C27B87E0DB@in.WebX.maYIadrTaRb">news:C94510C3B091446A47DD64C27B8......
I was under the impression that if you installed
the SDK Apprentice was installed as well. Apprentice is usually used for
people who don't have Inventor installed. Kind of an Inventor
Lite. Let me know how it goes..
"MechMan" <mechman> wrote in messageMaybe
href="news:f144bef.5@WebX.maYIadrTaRb">news:f144bef.5@WebX.maYIadrTaRb...
this is what's needed? I don't understand what MYRIAD is.
href="http://www.infograph.com/support/MyriadInventor.htm">http://www.infograph.com/support/Myria...
href="http://www.infograph.com/support/MYRIADTechnicalSupport.htm">http://www.infograph.com/suppo...
MechMan
"MechMan" <mechman> wrote in messageI
href="news:f144bef.8@WebX.maYIadrTaRb">news:f144bef.8@WebX.maYIadrTaRb...
posted our problem to Informative Graphics Corp and included a link to this
thread. I guess by using the link it also allowed Dennis to post the above
thread as me. Didn't know that one.
Here's an easier to read version of what Dennis posted.
The previous released version of ModelPress Publisher does not support
(Apprentice 6.0) Autodesk's Design Tracking Version 6.0. As a result of this
the previous ModelPress Publisher will not publish Inventor 6.0 files.
The newest released Version of ModelPress publisher support Design Tracking
6.0 (Apprentice) for Inventor 6.0 support.
Download the newest version
from the ModelPress website.
(Apprentice) Design Tracking 6.0 must be installed prior to installing
ModelPress Publisher. If ModelPress Press Publisher was installed Prior to
(Apprentice) Design Tracking 6.0 then one of the DLL files for (Apprentice)
Design Tracking 6.0 must be registered Manually to do this open a DOS Command
Prompt Window and change directories to:
c:\Autodesk\Design Tracking
6.0\Bin> (this is based on a default install of (Apprentice) Design
Tracking 6.0 if you insatlled (Apprentice) Design Tracking 6.0 in a location
other then the default change to that directory.)
Then at the command
prompt type RxApprenticeMarshal.dll -Register
Example: c:\Autodesk\Design Tracking 6.0\Bin>RxApprenticeMarshal.dll
-Register
This is nessasary due to a bug in the (Apprentice) Design Tracking
installer that does not register the RxApprenticeMarshall.dll. ModelPress
Publisher installer is designed to register the RxApprenticeMarshall.dll but
it can only do this if Design Tracking 6.0 is installed prior to Model Press
Publisher being installed.
The Real MechMan B-)
href="news:D3D70488D2B4707711EB7F064D2B6EDF@in.WebX.maYIadrTaRb">news:D3D70488D2B4707711EB7F064D2......
Well I think that if you do a full install of R6
you get Apprentice. And I didn't have a previous version of Model Press
installed on this machine. So it appears that this doesn't apply to my
situation but it still doesn't work...
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
files.
Tracking 6.0 (Apprentice) for Inventor 6.0 support.
Download the newest
version from the ModelPress website.
Command Prompt Window and change directories to:
c:\Autodesk\Design
Tracking 6.0\Bin> (this is based on a default install of (Apprentice)
Design Tracking 6.0 if you insatlled (Apprentice) Design Tracking 6.0 in a
location other then the default change to that directory.)
Then at the
command prompt type RxApprenticeMarshal.dll -Register
-Register
href="news:977883A73F8A6AC5FB5D92A98BCEE415@in.WebX.maYIadrTaRb">news:977883A73F8A6AC5FB5D92A98BC......
BTW C:\Program Files\Autodesk\Inventor 6\Bin is
on my system and is installed with R6. Seems like they have other
bugs.
href="news:D334341DA9E3E2D32442C1CACBB34BD4@in.WebX.maYIadrTaRb">news:D334341DA9E3E2D32442C1CACBB......
I tried to re-register the DLL but still no
joy. I wrote Dennis an email to this effect. I'll post back when
he replies.
Sean Dotson, PE
Check the Inventor
href="news:977883A73F8A6AC5FB5D92A98BCEE415@in.WebX.maYIadrTaRb">news:977883A73F8A6AC5FB5D92A98......
bugs.
