style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"MechMan" <mechman> wrote in messageIf
href="news:f144bef.26@WebX.maYIadrTaRb">news:f144bef.26@WebX.maYIadrTaRb...
I'm right I'll be 3 for 3 today with my guess work. What a day! B-)
I fear tomorrow. =8-O
MechMan
"MechMan" <mechman> wrote in messageShouldn't
href="news:f144bef.22@WebX.maYIadrTaRb">news:f144bef.22@WebX.maYIadrTaRb...
make a difference but I published mine directly to the
Desktop.
MechMan
"Brian Corbin" <
href="mailto:brian@cadsense.co.nz">brian@cadsense.co.nz> wrote in
message
href="news:F8B0D359F1AF8DBC79F6C3FE8D25DE75@in.WebX.maYIadrTaRb">news:F8B0D359F1AF8DBC79F6C3FE8D2......
OK here's the answer (I hope)
I downloaded the new MP Publisher (which includes
the viewer) I did not install or download the appretice thingy.
The only way I can get it to publish is if I
first open the viewer and leave it open the open the publisher, then publish
an INV 6 file and it works...
Anybody else?
Brian
Desktop.
MechMan
Brian, you running Sp1 or 2?
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
MechMan
"MechMan" <mechman> wrote in messageNow
href="news:f144bef.31@WebX.maYIadrTaRb">news:f144bef.31@WebX.maYIadrTaRb...
if we can just find someone still on SP1 to validate our theory that SP2 is
causing the problem.
MechMan
"The Head of 3D Engineering in our conversation about this yesterday said
that yes in some cases ModelPress will kind of work with Inventor 5.2 and 6.0 at
some service pack levels however, our engineers have spent much time working
with the AutoDesk Inventor Engineering team. The facts are that the
application's support files and APIs between Inventor and Design Tracking are
vastly different."
"Engineering has spent countless hours attempting to find solutions to the
differences in the API's. As the applications (Inventor and Design Tracking)
dlls have the same names and the APIs are so different they determined it would
not be possible. While Engineer did not add code that prevent ModelPress from
using Inventor, the possibility that the ISF file is accurately created even if
ModelPress does output the ISF file would be highly questionable. In the
hundreds of thousands of tests conducted by our Engineers they found too many
unacceptable problems with the ISF file created with using Inventor 5.3 and 6.0
as the support application for the translation of the Inventor files to
ISF."
"MechMan" <mechman> wrote in messageBased
href="news:f144bef.37@WebX.maYIadrTaRb">news:f144bef.37@WebX.maYIadrTaRb...
on what Dennis said it's odd that it's working on this computer. I forgot to
mention that I also have R5.3 installed so maybe that's the difference? Here's
a recap...
Win2k SP2
IV R5.3 SP2
IV R6 SP1
Installed ModelPress Publisher for
IV R6 and converted parts and assemblies with no problems.
MechMan
