Inventor Forum
Miter Folds
15 REPLIES 15
Message 1 of 16
1214 Views, 15 Replies
Miter Folds
Has anyone figured out how to do a miter fold yet? If you don't know what
that is, picture this:
Take a strip of material say 4"x48"x1/2", chamfer the 2 short ends @ 45 deg,
cut 3 45deg v-grooves at equal spacing & leave .030" material at the bottom
of the groove. Now fold the machined part into a rectangle. Maybe one of you
sheet metal gurus can help me here.
Thanx, Dave
15 REPLIES 15
Message 2 of 16
I would think it could be modeled without to much hair pulling, but I doubt you will be
able to unfold it.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Dave Hoder" wrote in message
news:963038B2A0AF04CE775DF5DE9F07DA28@in.WebX.maYIadrTaRb...
> Thanx, Dave
Message 3 of 16
I need to show it as one part (with the original part size) in the BOM &
unfold it for machining. Right now I'm faking it by making a drived part
from a dummy unfolded assy & hiding the separate parts in the Parts List.
This won't be a good idea though as soon as we start pulling data directly
from assemblies. Any ideas?
Message 4 of 16
Create flanges using the offset option. make the offset longer then the
flange width. This will leave large gaps between your flanges. Use the
corner tool to close the flanges. This will give you a mitered corner.
I have placed an example in Customer Files.
>Thanx, Dave
Message 5 of 16
I could easily be wrong, but I don't think that is what he is after. The
words 45deg v-groves and Machined parts makes me think he wants a weakening
grove to make the fold with.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
"Charles Bliss" wrote in message
news:3E4B1502.5000604@cbliss.com...
deg,
bottom
Message 6 of 16
Can you post what you have in CF?
Matt
Message 7 of 16
Matt
If you are talking to Charles... He did! 8^)
Kent
"Matt Hendey" wrote in message
news:f1431d6.4@WebX.maYIadrTaRb...
> Matt
Message 8 of 16
No to Dave, Sorry. I'm interested in what he is trying to do. I tried
creating the part from the description he gave but if I got it right, I
can't see the reason for building a part that way. No that there isn't one.
Matt
"Kent Keller" wrote in message
news:1B117C461A3FF93F56B7ACC5468940BB@in.WebX.maYIadrTaRb...
> Matt
> Kent
> > Matt
Message 9 of 16
The part is in CF called Miter Fold. (I just made an example shape, not a
sheet metal part) This is a common manufacturing process in the furniture /
woodworking industry where we are working with a piece of wood covered with
a colored paper. We cut thru the wood & leave the paper, then fold the whole
thing together. This makes for a cleaner seam & less assemby time.
Thanks for having a look.
Message 10 of 16
I did one of those by ... cheating? ... making a face that would bend then
add the rest in an assembly because it needed to be shown both flat and
folded.
~Larry
news:F82FB0D513739B07DFE1A95A4327C751@in.WebX.maYIadrTaRb...
with
whole
Message 11 of 16
I tried starting a sketch on the back and projecting the bottom of the V then setting the
SM thickness to .03, and doing a fold. It just flipped the whole part 90º and made a
weird looking bump on the backside 8^)) I wonder if you possibly made the bottom of
the V groove flat a small amount, and placed a fold in the middle of the flat?
BTW In the future could you please zip files before posting. It makes them smaller and
also non zipped files often lock up Outlook Express. Thanks.
Kent
Message 12 of 16
Oops! I just discovered the non-zipped file issue. The file has been
re-posted as Miter Fold 2.
Message 13 of 16
Dave take a look in CF under your last post.
Is this what you're after?
news:B6FA5EFB249CDB1D5C031491A90B0FC4@in.WebX.maYIadrTaRb...
Message 14 of 16
Dave
Not exactly what you want, but see if the file I posted back would work. The web
thickness in that file isn't what you want, ... I meant to change it to .03 after I did a
couple of things, but forgot. It is real touchy and will never be perfect but...
depending on what you need it might work??
Kent
Message 15 of 16
Good show Kent. I like that. It worked, that's the important part. Actually,
I would think that's the way it would have to be cut anyway.
Matt
Message 16 of 16
Super_Steve
Miter Folding with Inventor is a snap take a look at the tutorial
www.youtube.com/widomtech   ...... 23 minute tutorial with "Ilogic"
