Inventor Forum
Mirror
4 REPLIES 4
jetpro
164 Views, 4 Replies
Mirror
Hi to All,
How can I Mirror an object??
When I miror it, I allways get the object that was before I made the final cuts on it.
It mirrors the original solid and not the finished one.
Joe
4 REPLIES 4
in reply to: jetpro
Not sure I understand what an "object" is.... You can select multiple
features to mirror on a part or if you want to mirror a part, go with a
derived part. If you can't get it working, perhaps you could post an example
of what you are trying to do.
Jeff
"jetpro" wrote in message news:f124299.-1@WebX.maYIadrTaRb...
Hi to All,
cuts on it.
Joe
in reply to: jetpro
Can I mirror a part or subassembly in a main assembly
I sure would like to do that.
Example; say I have an angle knee bace at 45 deg
in a steel struture, I would like the brace mirrored at the other end.
I would avoid having to insert all the parts and re-constraint.
Gaetan Scherer
Atara corp.Canada
in reply to: jetpro
I'am sorry if this post appears 3 times including this one
but it shows up in my sent folder but not on NG
Gaetan Scherer
Atara corp.Canada
in reply to: jetpro
Gaets
It has the same Subject as a older post, so it is showing up as a reply to
that. Currently I only see two posts from you.
AFAIK your options are to do a derive and choose the mirror option, then
insert that file and constrain it or there has been a link to a program that
supposedly mirrors part, but I don't know of anyone that has tried it. I
think it is still using the derived feature, but it automates some of the
steps??
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Gaets" wrote in message
news:A5A12ABA277376E39FA2BA17A6928462@in.WebX.maYIadrTaRb...
> Thanks
> Gaetan Scherer
> Atara corp.Canada
