Inventor Forum
Mirror command?
11 REPLIES 11
Message 1 of 12
wmd2
975 Views, 11 Replies
Mirror command?
In the attached file is an illustration of a vise base. What is an expedited technique to duplicate the padeyes seen in the isometric view to the other side? Thank you in advance
Will
11 REPLIES 11
Message 2 of 12
machiel.veldkamp
in reply to: wmd2
You need a work plane in the center of the model you're working on.
You can either do that by editing your first exstrusion and place that one in the center (then you're done (exept the model freaks out..)) or, you can make a new work plane by pressing ']' and selecting the two oposite sites of your model, then a work plane will be placed in the center of those to planes.
Then you have a usable workplane that you can use.
___________________________
Message 3 of 12
wmd2
in reply to: machiel.veldkamp
In fact it did freak out. The attachment shows the following run time error; R6025 pure virtual function call
Message 4 of 12
JDMather
in reply to: wmd2
Attach ipt files, not pictures.  Can't edit pictures or see clearly what you did in pictures.
Doesn't look to me like you have created correct mirror plane as shown in previous response.
Message 5 of 12
JDMather
in reply to: JDMather
Your Sketch1 is not constrained or placed with a logical orientation to the origin.
I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Message 6 of 12
JDMather
in reply to: wmd2
Line not vertical?
Line has unmanufacturable dimension
Extra horizontal line at bottom.
Horizontal line at top not dimensioned.
Message 7 of 12
wmd2
in reply to: wmd2
Attached please find the sketch in its current form. Thank you
Message 8 of 12
JDMather
in reply to: wmd2
Why?  Did you attach the correct file?  You didn't fix any of the issues in this file and there is no mirror plane?
Message 9 of 12
wmd2
You are very responsive. And your responses are very anticipatory. But that's good
Message 10 of 12
JDMather
in reply to: wmd2
Extrusion1 should be mid-plane (Symmetric).
Sketch2 is not constrained.
Sketch7 is not constrained.
Sketch9 is not constrained.
Message 11 of 12
wmd2
in reply to: wmd2
Implemented all of your suggestions. .pdf attachment, Skills University was highly useful. It seems there are many steps to applying the mirror command. However, the browser makes things easy and thus it is highly indispensible. Thank you again
Message 12 of 12
JDMather
in reply to: wmd2
Not really.
Attach your file here - I suspect you are still doing too much work.
