I want to mesure the minimum distance between 2 parts. But I want Ilogic to know what parts to mesure according to what i've selected.
I have something like this but its not working... gives me always this error "
Measure.MinimumDistance: No entity named "System.__ComObject" was found."
any help? thanks!
Dim oOccurrence As ComponentOccurrence Dim oOccurrence2 As ComponentOccurrence Try oOccurrence = ThisDoc.Document.SelectSet.Item(1) oOccurrence2 = ThisDoc.Document.SelectSet.Item(2) Catch MessageBox.Show("Please select a component before running this rule.", "iLogic") Return End Try Dim doc As Document Dim CurFileName As String oOccurrence = ThisApplication.ActiveDocument.SelectSet.Item(1) oOccurrence2 = ThisApplication.ActiveDocument.SelectSet.Item(2) distance = Measure.MinimumDistance(oOccurrence,oOccurrence2) MsgBox(distance)
Hello there,
wouldn´t it be possible to compare the object coordinates to give you what you want?
Kind regards
Daniel
