Inventor Forum
Microsoft Security Essentials and Inventor
6 REPLIES 6
coemter
766 Views, 6 Replies
Recently i updated all workstations to Microsoft Security Essentials (MSE) anti virus. Now we notice some big performance issues when loading and saving to the Vault store.
The MSE is in default configuration, including real time protection.
Can this be a reason for the performance issue ?
And what will be the best configuration (if any)  of MSE to work with Inventor ?
6 REPLIES 6
ampster401
in reply to: coemter
I use WSE and have no issues.  There was nothing that needed configuring in WSE in order to function with Inventor.
If you had McAfee or Norton, you may have left over stuff in the registry and such.  I know Norton provides tools to completely uninstall their software on their website, I don't know if McAfee odes however.
edit, however I do not use Vault so maybe there is something there, I can't imagine WSE would be scanning native Inventor files...
mcgyvr
real time protection is scanning the files.. Typically with most virus programs you can add file extensions to ignore.. (I always put .iam, .ipt, .idw,etc.. into the ignore list or you can put a folder to ignore.
Simply turning off real time protection to see if it gets faster again. (then add the ignore list and turn it back on)
karthur1
I use MSE too on about 10 workstations.  No issues here.
What version of Vault are you using?
coemter
Thank you for your input.
I was observing how disable real time protection change the performance. Without real time protection enabled performance is as before installing MSE.
[ Inventor + Vault 2011 ]
hans.martin.haga
You can configure MSE to only scan new incoming files, and also exclude entire folders or file types. See the settings tab.
karthur1
in reply to: hans.martin.haga
I could be wrong, but I think that "exclude files,file types and process" from the system scan.  This helps speed up the system scan, but doesnt do anything to reduce the resources that MSE uses.
With the Real-Time protection turned on, you can choose to monitor all files, only incoming files or only outgoing files.  I dont see any way to exclude only certian process from the real-time protection.
