Inventor Forum
Memory usage according to the 'Memory Usage Meter'...
5 REPLIES 5
KF090
784 Views, 5 Replies
After working on multiple files (a few ipt's and an iam), I closed all the files but the MUM still was in the yellow.  I gave it a few minutes and it didn't not drop at all.
Why does Inventor sometimes NOT release the memory it had been using well after all files are closed?
I had to completely shutdown Inventor in order to gain access to that memory again.
5 REPLIES 5
mcgyvr
in reply to: KF090
Its actually done that way on purpose. Inventor is supposed to keep stuff in memory to allow you to open it quicker the next time. Its sometimes good and other times is a silly function. Closing and reopening Inventor will clear that as you have found.
Ray_Feiler
in reply to: KF090
Also some of it has to do with undo file size.
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
KF090
in reply to: mcgyvr
Is there anyone to change a setting so that is does not cache any files?
johnsonshiue
in reply to: KF090
Hi! If you want to turn off the file caching activity behind the scene, there are two ways to do that. Please keep in mind, without caching, next time you open the same file will take the same time as you open it first time.
On Inventor, go to Application Options -> File -> uncheck "Enable Quick File Open" option at the bottom.
On Win7 or Vista, you may consider turning off a service called Superfetch.You will be turning off a default Windows function. Please search for relevent information on the web and understand clearly the consequence of turning off the option before you proceed.
Thanks!
Software Test Engineer
in reply to: johnsonshiue
Hi, This is a little after the fact, but I'm having the same issue and unchecking "Enable Quick File Open" didn't fix the problem.  I use XP and Inventor 2012.  When I close files the memory drops a little bit, but most of it stays cached.
