Inventor General Discussion
Distinguished Contributor
StuartMoore
Message 1 of 13 (1,092 Views)
Math & Trig Functions
1092 Views, 12 Replies
02-23-2004 09:44 AM
Where can I find details of the correct syntax for Math & Trig functions for equations in parameters?
*Mike Maenpaa
Message 2 of 13 (1,092 Views)
Re: Math & Trig Functions
02-23-2004 09:49 AM in reply to: StuartMoore
In the Help file, search for Edit Box Reference. Mike "StuartMoore" wrote in message news:13104293.1077558281179.JavaMail.jive@jiveforum1.autodesk.com... > Where can I find details of the correct syntax for Math & Trig functions for equations in parameters?
StuartMoore
Message 3 of 13 (1,093 Views)
02-23-2004 10:03 AM in reply to: StuartMoore
The search found nothing of use. Can you be more specific?
*Kent Keller
Message 4 of 13 (1,095 Views)
02-23-2004 10:09 AM in reply to: StuartMoore
It should have turned up lots of things. Try this instead, I think it might narrow the hits down algebraic operators -- Kent Assistant Moderator Autodesk Discussion Forum Moderator Program "StuartMoore" wrote in message news:31268272.1077559464225.JavaMail.jive@jiveforum1.autodesk.com... > The search found nothing of use. Can you be more specific?
*Glenn Chun \(Autodesk\)
Message 5 of 13 (1,095 Views)
02-23-2004 11:43 AM in reply to: StuartMoore
Search for "cos" in the Help, and Inventor will list the following topics: Edit box parsing example table Edit box reference HTH, Glenn
*MP
Message 6 of 13 (1,095 Views)
02-23-2004 11:38 PM in reply to: StuartMoore
http://www.mossdesigns.com/inventor-tips.htm "Glenn Chun (Autodesk)" wrote in message news:403a57f1$1_3@newsprd01... > Search for "cos" in the Help, and Inventor will list the following topics: > > Edit box parsing example table > Edit box reference > > HTH, > Glenn > >
*MP
Message 7 of 13 (1,095 Views)
http://www.mossdesigns.com/inventor-tips.htm "StuartMoore" wrote in message news:13104293.1077558281179.JavaMail.jive@jiveforum1.autodesk.com... > Where can I find details of the correct syntax for Math & Trig functions for equations in parameters?
StuartMoore
Message 8 of 13 (1,095 Views)
02-24-2004 03:55 AM in reply to: StuartMoore
Thanks for your help but I still cannot get IV to do what I want.
I am trying to create a sphere using the volume to drive the radius. I make a user parameter called SpereVolume and input the volume I want. I am not sure of the units to use here since IV only allows litres or gallons. However, it shouldn't matter if the number is unitless since it is only being used to calculate a radius which has mm units. The equation I am using to calculate the radius is:
=((3*ShereVolume)/(4*pi))^(1/3)
IV's response to this is "Unable to parse equation".
Any ideas would be most welcome.
StuartMoore
Message 9 of 13 (1,095 Views)
02-24-2004 04:18 AM in reply to: StuartMoore
A further observation: if I replace pi with the numerical value IV accepts the equation but the answer it gives is exaxtly 10x too big and the equation stays red in the box.
StuartMoore
Message 10 of 13 (1,095 Views)
02-24-2004 04:59 AM in reply to: StuartMoore
OK, I worked it out. Volume must be entered as litres and pi should be PI.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
