Inventor Forum
Material delete and type mismatch
13 REPLIES 13
Message 1 of 14
orchjam
1101 Views, 13 Replies
I'm trying to delete a material called "Generic" from a part..  I can't delete the material (delete greyed out) I try to add another material to the document and I still can't delete the "Generic" material...  I added a new material from the drop down box at the top... It says the correct material but when i open the material library dialog again it says "generic" instead of the proper material name that I selected... Is this a bug? See picture.
Please help!!!
Thanks..
13 REPLIES 13
Message 2 of 14
JDMather
in reply to: orchjam
Why do you need to delete the Generic material even if it is not assigned to the part?
I think if you right click and Assign Material you can then right click on the Default and Delete.
You don't indicate what version of Inventor you are using.
I don't see your attachment?
Message 3 of 14
orchjam
in reply to: JDMather
It is assigned to the part.  The problem is that I want to get ride of the gerneric material... It's causing some problems with FEA...
Message 4 of 14
JDMather
Why are you trying to run FEA with Default material (water density) rather than Assigning a valid material for FEA?
Message 5 of 14
JDMather
@orchjam wrote:
..... I try to add another material to the document and I still can't delete the "Generic" material...
Thanks..
Y
You can add several materials - did you Assign any of them before trying to delete the De
Message 6 of 14
Logos_Atum
As far as I know you can delete it as soon as it´s not assigned to anything anymore.
Dogs aren´t flammable.
Message 7 of 14
orchjam
in reply to: Logos_Atum
Well its simply not working.. and the "generic" material seems to be taking on the characteristics of another material.  This is strange.  Any other suggestions?
Message 8 of 14
JDMather
Attach file here that exhibits this behavior.
Do you see the same behavior if you create start a new file and create a simple cube?
Have you rebooted the machine?
All SP and Updates installed?
Message 9 of 14
orchjam
Message 10 of 14
JDMather
I could not delet the Default in 2013.
I am not at my 2014 machine to try there.
Message 11 of 14
orchjam
Could it be that the file is corrupt?  That's what I'm thinking..
Message 12 of 14
mrattray
I've never been able to delete the"generic"material from my files. I just rename it to "do not use". What problem is it causing you? If the part is assigned to a real material it should be fine.
Mike (not Matt) Rattray
Message 13 of 14
-niels-
Does it go away if you purge it from the file?
Manage tab -> Purge
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 14 of 14
orchjam
Hi... That worked to get rid of the material.. When I go to add another material now it doesn't show in the docment materials area but it says its there.
