Hello All,
I created the gear (helical) in the attached file using the standard gear tool in inventor. The problem is how do i then find the mass moment of inertia of it using Inventor?
Thanks!
Jimmy
Nothing showing up in the iProperties>Physical tab for the part.
You will need to step into the part model. If you used the Design Accelerator, it is at the Assembly level.
