I use simple set of iLogic rules to manage product configuration through the assembly LOD. Assembly is really simple not more then 30-50 parts. Still I manage to crush Inventor fairly often. Some days 5 and more crushes! Several times sent crush report to AutoDesk for no joy. Never got any feedback.
I wonder if someone uses LOD+iLogic as assembly configuration tool and experience that kind of troubles. I am just getting an impression that Inventor does not like LOD manipulated with iLogic for some or the other reason...
Hi, Assembly is parameter driven through linked Excel spread sheet. I am always using one and same LOD called "Option" to generate a new product configuration (based on Excel input) by suppressing parts/constrains with help of iLogic.
Yes it really so simple as you describe. I did try with iPrts/assemblies but found this more complicated and really useless as proper CONFIGURATION management tool when it comes to hundreds different combinations of components.
I can try to post my files over week end. Thank you so far.
Like you i have one custom Lod (I name it ilogic) and use componentIsActive and ilogic rules to configure the Assembly.
I have multiple users using my assemblies every single day and rarely (almost never) have issues
