Inventor General Discussion
New Member
caleb.leftwich93
Message 1 of 14 (1,285 Views)
Making a rectangular spring
1285 Views, 13 Replies
05-02-2012 12:44 PM
I have to make a spring for an engineering class I have yet me nor the teacher know how to make a rectangular spring. So please help me try to make it!
JDMather
Message 2 of 14 (1,269 Views)
Re: Making a rectangular spring
05-02-2012 01:05 PM in reply to: caleb.leftwich93
3d intersection between helix surface and extuded surface
then sweep
attach your attempt here for further instruction.
I recommend that your teacher go through ALL of the tutorials/papers in my signature and especially the Knot tutorial.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Curtis_Waguespack
Message 3 of 14 (1,263 Views)
05-02-2012 01:08 PM in reply to: caleb.leftwich93
Hi caleb.leftwich93,
Here's an example file that you can look at to see how it's done.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
JDMather
Message 4 of 14 (1,248 Views)
05-02-2012 01:27 PM in reply to: caleb.leftwich93
Here is another example with subtle differences - the key difference is the swept circle is on a plane perpendicular to the start point of the path to ensure the wire cross section is round.
The example isn't perfect using this helxi intersection method - but should be close enough.
If you need closer to perfect - post back and someone will suggest a slightly different intersection for the path.
Member
DerekRoes
Message 5 of 14 (256 Views)
04-30-2014 08:22 AM in reply to: JDMather
I know this is an old thread but I am drawing basically the same thing right now and am having some problems.
I used the file you posted but your lines are not straight. All of the lines going vertically (they are slanted I know, but essentially vertical) are bent in the middle instead of being straight. Is there a way to correct this?
Thank you.
JDMather
Message 6 of 14 (251 Views)
04-30-2014 09:23 AM in reply to: DerekRoes
Something like this?
Member
DerekRoes
Message 7 of 14 (233 Views)
04-30-2014 10:19 AM in reply to: JDMather
Sorry, I am using 2012 so I cant open it.
Member
DerekRoes
Message 8 of 14 (203 Views)
04-30-2014 11:33 AM in reply to: JDMather
If I use a small pitch the transition between bends is straight but if I stretch the pitch out, it distorts the wire.
JDMather
Message 9 of 14 (198 Views)
04-30-2014 11:38 AM in reply to: DerekRoes
I attached an example with straight lines - but you did not indicate in your problem description that you are using an older version of Inventor.
JDMather
Message 10 of 14 (195 Views)
04-30-2014 11:40 AM in reply to: JDMather
the 2d sketch
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
