Hi all
I have made some punches for sheet metal and this one seems to be simple but it has me stumb. Please help.
Its 50mm in Dia a 5mm lip a 28mm outside rad cone and a depth inside of =/- 8.5mm then there is a 12mm hole
Solved by JDMather. Go to Solution.
Charlie Bliss has several complex punches on his site that include the source part. You should download the parts and use the End of Part marker to step through each sketch and feature.
http://www.cbliss.com/inventor/iFeatures/index.htm
