I have a users machine that is displaying some odd behaviour. Their Macros and VBA Editor buttons have stopped working. We have tried several things already but nothing appears to have any effect.
Any suggestions?
Here is an update of the behaviour from my colleague; (Worth noting we are using our own project file and have the App Options pointing to a local server where the edited Default.ivb sits).
IT did a reinstall on pc but it still doesn’t work.
I tested it on another new win7 pc and it had the same problem.
We’re a bit at a lost, because there seems to be no structure here.
I’ve checked with all new win7 machines that are in use now, of which 4 work ok, 6 not.
On the win7 test machine I got te message from the attached screen print.
If I try to do macro when I have a part open I get nothing
If I try to do macro when I have a drawing open I get this message:
And then nothing.
If I try to do macro with no file open I do get the macro window,
If I do VBA editor I get the editor but it says “no project”, even if I open a file which has code in it.
Anyone care to take a punt at this one?
Can we assume that all Win7 systems had Inventor installed using these instructions?
http://teknigroup.com/support/InstallAdsksoftware.html
Ah, no Dennis we cannot assume that. We are subject to corporate IT and i doubt all of the items would have tick beside them. I shall pass it on.
I would like to assume however that all the installations were done in the same way and majority of them are working including my own. For the sake of a solution though i will ask them to re-do one machine as per the link and will report back.
Thanks.
Without getting into other things this problem has still not been resolved. There is no project loaded in the VBA editor. I managed to find one other example of this on the web where a persons Outlook vbaproject.otm file had been corrupted.
I did a search but cannot find this file on the mahchines. Is there an equivalent file that somehow controls the vba window for Inventor?
Really want to avoid imaging this machine. Is no-one willing to even take a guess?
We have the same problem. VBA Editor and VBA not working on a win7-64bit machine. Found a solution yet?
Klaas De Smedt
Hi. No solution yet. I have been through many more things that i have not listed here. Also Rocky has posted a few times on another thread i have in the customization forum.
Have you tried coping the Default.ivb to "C:\Program Files\Autodesk\Inventor 20XX\bin\Macros" and updated your App Options?
I was working on one of our workstations the other day and could not get a macro to run (using Inv 2011). Tried to start VBA editor to see if it was even loading and the editor would not start. Reboot didnt help. So I turned off the UAC and did a repair installl. Rebooted and it started working then.
I ma sure you have done all of that, but that is what worked for me.
Hi. We had already uninstalled/reinatelled once but i tried repairing again for good measure. Still not working though.
Today I found the solution of the VBA mystery.
My plan of attack:
I noticed the only difference with other computers where the VBA module worked was the installation of Inventor 2011 (This is not the cause of the problem). So i did on the problem computer.
Whet running the VBA in Inventor 2011 I got the following error:
object library invalid or contains references to object definitions that could not be found
Google told me something of activeX and cash files. In short, you have to delete all the activeX cashfiles to solve the problem so i did. After that, VBA worked again in 2011 and 2012.
How to remove activeX cash files:
open the command window (cmd.exe) and type:
cd c:\ DEL /S /A:H /A:-H *.EXD
Essentially the command recursively deletes all your hidden and exposed exds. That will make all your activeX components load a bit slower the first time you use them again, but it should also clear out the problematic ones.
regards,
Klaas De Smedt
It's solved here!
But I can't say it's whether because of clearing the cashfiles or installing the SP1 for Inventor 2012 (I did both).
So Klaas I would say half a kudo!!
Installing the SP1 did not work for me and for Inventor 2011 so i must be the cashfiles 😉
Same Problem here..
Inventor 2014 (came with FDS2014), VBA Editor /MAcros button is not working.
Load VBA on start-up is not available in Application Options.
Can somebody point out me in right direction.
AD
this software the support is very lousy.
also select the very expensive parking place for seminal,
when I make a complaint . staff from Autodesk ask me to take public transport. Them funny.
