You can use the Drawing Resource Transfer Wizard to get any of the items sent to the drawing, but you will still have to delete and replace with the new items, I imagine a macro for thsi would be ten times easier.
trevorauman Wrote:
You can use the Drawing Resource Transfer Wizard to get any of the items sent to the drawing, but you will still have to delete and replace with the new items, I imagine a macro for this would be ten times easier.
Not so if the title blocks and borders are named the same and you check the option to replace the same not copy it will change the title block so you would not have to delete and reinsert but you may have to open tem so any information that was taken from the model or the idw will get populated..
