Inventor Forum
Macro Add thickness + trailing Zeros
9 REPLIES 9
Message 1 of 10
685 Views, 9 Replies
What code allow to create a macro button with :
In parameters :
- Check : Thickness
- Check : Trailing zeros (in "Custom property format")
9 REPLIES 9
Message 2 of 10
mrattray
Try this:
Dim oDoc As Document
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
Dim oParam As Parameter
Dim oParamFormat As CustomPropertyFormat
oDoc = ThisDoc.Document
If oDoc.DocumentType <> kPartDocumentObject Then
	MsgBox("This rule is only valid for part documents.", vbOKOnly, "Error")
	Exit Sub
End If
Try
	oSheetMetalCompDef = oDoc.ComponentDefinition
Catch
	Try
		oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
	Catch
		MsgBox("Part must be a sheet metal part. Please click the Convert Part to Sheet Metal button!",vbOKOnly,"Error")
		Exit Sub
	End Try
End Try
Try
	oParam = oSheetMetalCompDef.Parameters.ModelParameters.Item("Thickness")
	oParam.ExposedAsProperty = True
	oParamFormat = oParam.CustomPropertyFormat
	oParamFormat.ShowUnitsString = False
	oParamFormat.ShowLeadingZeros = False
	oParamFormat.ShowTrailingZeros = True
	oParamFormat.Precision = kThreeDecimalPlacesPrecision
Catch
	MsgBox("Failure to format: Thickness", vbOKOnly, "Error")
End Try
You can change the value of each true false statement to suite your needs. It should be self explanatory.
Mike (not Matt) Rattray
Message 3 of 10
in reply to: mrattray
Thank you for your reactivity,
But the macro is blocking at :
Pop-up "Compile error: Invalid use of property"
"oDoc ="
Message 4 of 10
mrattray
This is written for iLogic. It sounds like you're trying to use this in the API. They use different languages. Can you use it as iLogic?
Message 5 of 10
I would like to use this macro only sometimes, and don't to depend of one rule in a file.
Message 6 of 10
mrattray
If you save it as an external rule you can call it at will from the iLogic browser without having to add it to your files.
Message 7 of 10
It's working with some modifications
oParam = oSheetMetalCompDef.Parameters.ModelParameters.Item("Epaisseur")
I deleted the last msgbox because the box shows "Error", then there is no error !
Thank you !
Just for my information, what advantage to use iLogic rather than "VBA" ?
Message 8 of 10
mrattray
Sorry, I missed that you were using a different language than English. If you're getting the error message, than I would be concerned that one of the lines in the property formatting is not getting executed for some reason or another. Can you test and verify that it's actually changing each format option?
iLogic is a little easier to run directly from Inventor (in my opinion, anyways), but more significantly it offers some .NET functionality (like the Try Catch statements I used here) that is not available using traditional VBA in the API.
Message 9 of 10
Curtis_Waguespack
Hi amartin.r,
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Message 10 of 10
This msgBox appears same there is no problem for execute the code.
