Would it be better to use a loft instead of a sweep or extrude? I'm imagine making a few cross-sectional sketches, perhaps at quadrant points around the perimeter, should be within "fudge-able" margins for the desired effect.
This is a very old thread. The soluton has changed.
Inventor now has an Equation Curve funcion.
Pretty sure there are some youtube examples.
What is the formula for your desired curve?
@graemev wrote:Would it be better to use a loft instead of a sweep or extrude? I'm imagine making a few cross-sectional sketches, perhaps at quadrant points around the perimeter, should be within "fudge-able" margins for the desired effect.
Can you post an example ipt file that demonstrates this technique?
To tell you the truth I'm not really sure. I just know that It needs to look like this.
It's ugly rough for an example, but you get the drift. Size, math, and quantity of sketches involved to your taste.
The thing is, I have to make it a line, not a profile. Like, in sketch mode.
Have you tried using Equation Curves yet?
