Inventor Forum
Lofts
3 REPLIES 3
ahogue
368 Views, 3 Replies
Lofts
You can loft to loops.
You can loft to points.
But you can't loft to a line segement.
This isn't to say that i need to loft a shape to an infinite ray or axis.
I need to loft to a line that has a length.
Help?
3 REPLIES 3
CCarreiras
in reply to: ahogue
Hi!
You can do it, but not in only one loft... but it's possible anyway
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CCarreiras
mrattray
in reply to: ahogue
Can you post an example of you problem?
Mike (not Matt) Rattray
ahogue
in reply to: mrattray
Here is the example. I need to loft a cut from the first sketch to the second.
