Inventor Forum
Lofted Flange Ducting help
6 REPLIES 6
RobJV
388 Views, 6 Replies
I am trying to create a ducting chute and am having trouble creating a lip on the end.  I have drawn it simply using a boundary path and thickening but know that it will not unfold.  I know I can probably "cheat" and get something close but was wondering if somebody could take a look at the attached assembly (drag the eop markers down) and help me create the chute lip.  It should be sheetmetal and be allowed to unfold.  I am presently not sure which direction to pursue.
Rob
6 REPLIES 6
JDMather
in reply to: RobJV
You forgot to attach the part files.
Part must be created from planar, cylindrical or conic faces only or with the Inventor Sheet Metal tools.
RobJV
in reply to: JDMather
Sorry - was in a hurry Friday afternoon and grabbed the wrong file.  The zip file should be attached.
RobJV
Thanks JD - I am pretty adept at sheetmetal and most other parts of Inventor and understand how sheetmetal parts work - just having trouble figuring out a good way to construct the lip that I have shown as a representation only.  (Zip is now attached.)
Rob
4donwan4
in reply to: RobJV
I took a look at the parts you attached and not sure if sheet metal could do this due to the unfolding rules and reliefs it would need.
Don.
RobJV
in reply to: 4donwan4
Thanks for taking a look anyways.  I may end up just doing some approximations if nobody else has any bright ideas.  JD?
RobJV
in reply to: RobJV
I played with it a bit more and adjusted the lofted flange end sketch and then created a contour flange lip that should do the job.
Rob
