"Kent Keller" wrote in message
news:D3C158F8C6BBB948DC2F1502E12497A5@in.WebX.maYIadrTaRb...
> Unfortunately it isn't really the loft I need to fillets on, it is the
> 3d paths. The loft is just to create some 3d paths for diagonal
> supports between the first two 3d paths. Thought I had this figured
> out, but now I am beginning to question the approach I am using.
After the lofted surf is filleted the edge can be used for the sweep path? If
it won't accept the edge for a path maybe you can create new 3D sketches and
"Include Geometry" the edges.
> Any time I edit this 3d path the projected line turns pink. I was able
> to do some relational dimensions in this case to get around the need for
> the projected line, but other places I don't think that will work. This
> file has been closed and opened a number of times so that doesn't help
> any.
This may have something to do with the same database management problems that
I think are the reason for the "discontinuous sements" after filleting the
intersection curves. I've never attempted to manipulate intersection curves
(add fillets, etc.), so don't have much to offer. It seems it isn't a good
idea, at least at present.
> I just came across another interesting issue. If I have two same size
> tubes 90º to each other and extrude the second tube to the first it does
> it without problems if I use solids, but if I use surfaces it fails
> every time.
Yeah, this has always been a problem for Autodesk. A couple of releases back
it would fail even with solids (the intersecting tube would have to be some
minute amount smaller to get it to work). Why surfaces and solids react
differently is a mystery, as it all involves finding surface intersections to
establish trim lines. Possibly the surface normals (for non-solid faces)
contribute to the difference. I haven't played with it much, but it sounds
like Frans has got a handle on it.
> Oh well what fun would it be if everything worked like it is supposed
> to. 8^/
So true!
Have a good one.
