Inventor Forum
Local content center install location
2 REPLIES 2
donovandigital
364 Views, 2 Replies
I would like to install Content Center for Inventor to a separate partition for housekeeping purposes (local, not vault). However, the installer (Product Design Suite) will not allow me to proceed when I input my desired target path into the white textbox beneath the individual library components checkboxes (after expanding the item under the product list). The grey installation path textbox is not editable.
Is this simply not doable at install time? If so, can I move the libraries manually later?
Many thanks in advance
Joe
2 REPLIES 2
DarrenP
in reply to: donovandigital
can you post a screen shot?
it should allow you to edit the path for desktop content
i have mine set to D:\Inventor Content
DarrenP
ChrisMitchell01
in reply to: DarrenP
I don't know why you can't change location during install, but yes, you can move the files after installing.
By default the files will go in C:\ProgramData\Autodesk\Inventor 2014\Content Center\Libraries
Move the whole Libraries folder to wherever you need it & then start Inventor. Go to Tools, Application Options, Content Center tab & change the path there.
Hope this helps,
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
