I am using various lengths of tubing to draw flexible tubing sets. I created a 1" profile and use iParts to create the rest of the lengths. I used iProperties I was able to write a description and set the material for the 1" profile. This is fine for the material since it doesn't change but I would like to get a description of tubing parts with their specific cut lengths in the BOM as well.
So far, I have be successful in implementing the material via a column in the iPart table, but I have not been able to get anything to show up from the description column i made, much less link the description to the length of the part.
Any help would be greatly appreciated.
See attached. Edit the iPart table and enable the Properties tab. Hit that >> to add. You should then be able to edit the description.
You know I did that and thought that was the answer but it didn't corrolate with my dwg parts list. This was a content center part (sht mtl scr) which was converted to ipart for us so maybe that's the rub. It seems to carry the ANSI type standard from the content center. I appreciate your help. - greg
Well, it was worth a shot. Glad I almost helped.
