Inventor Forum
Lines disappear from IDW
12 REPLIES 12
Message 1 of 13
638 Views, 12 Replies
After I create my views in the IDW,
I can watch as many of the lines,
mostly hidden, will disappear.
I have an ATI Fire GL E1 video card,
is this the problem or is it something else?
12 REPLIES 12
Message 2 of 13
This is a bug and AutoDesk was already aware of
it.
After
mostly
is this
Message 3 of 13
Aren't hidden lines meant to
disappear?
Check your view definition
What probably happens is that your views are
getting "precise"
Rui
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">After
mostly
is this
Message 4 of 13
Are you taking about lines from a part you made
reference in "Occurance"?
After
mostly
is this
Message 5 of 13
What does "precise" mean.
Can I keep this from happening?
Message 6 of 13
When IV first creates a view, it is only a "rough draft" of the geometry. When
it goes precise, a background application takes over to finalize it. This
enables you to continue placing views and annotation while IV is doing heavy
number crunching. This is a good thing. You can change how the view looks by
clicking on the different icons in the Place View dialog. They look like
cylinders. They allow you to switch between shaded, hidden line shown and hidden
line removed modes. Click on the hidden line shown icon to do what you want.
BTW, you can stop Precise View creation, but I would not recommend it.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"GLovins" wrote in message
news:f18f824.3@WebX.maYIadrTaRb...
Message 7 of 13
P.S. ATI cards are known to be bad with Inventor. You will probably run into
problems down the road with it. Quadro4 cards are recommended, especially any
above 550.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"Dave Jacquemotte" wrote in message
news:13E62D48D40441F8D016A2D7E90CFFB5@in.WebX.maYIadrTaRb...
hidden
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
Message 8 of 13
It happens to any IDW file after I create my base or projected views. I'm not sure what you mean by, "reference in occurance". I do have the style set to show all hidden lines. All the lines do appear at first, but then disappear. If I can quickly saveas it will retain all the data in the copy.
Message 9 of 13
If you have a part model that exhibits the problem and can post it you could
probably weed out "installation specific" causes (see if others see the same
behavior). Are these all native parts or do you use a lot of imported data
(can be especially hard to get good views of)?
news:f18f824.6@WebX.maYIadrTaRb...
Message 10 of 13
Also when editing or creating a view you may want to select the second
tab on the dialog box and then check the 'show tangent edges' box. If
that is unchecked all the fillets and rounds do not show in your IDW.
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
Message 11 of 13
Dave you on your break or is the new boss tolerant of the other
package.............:)
Laurence,
Power is nothing without Control
news:1C6E7458CF333CC9DA8526AE7405C38D@in.WebX.maYIadrTaRb...
into
any
> above 550.
> Dave Jacquemotte
> Automation Designer
> www.autoconcorp.com
geometry. When
This
heavy
looks by
and
> hidden
want.
> > Dave Jacquemotte
> > Automation Designer
> > www.autoconcorp.com
Message 12 of 13
I'm in lame-duck mode. Gave my 2 weeks, but nothing to do. They'll probably tell
me not to come in next week, but who knows....
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"Laurence Yeandle" wrote in
message news:9F7F76CBF91A72FD0FD7A340F3E26A84@in.WebX.maYIadrTaRb...
> Laurence,
> into
> any
> > above 550.
> > Dave Jacquemotte
> > Automation Designer
> > www.autoconcorp.com
> geometry. When
> This
> heavy
> looks by
> and
> > hidden
> want.
> > > Dave Jacquemotte
> > > Automation Designer
> > > www.autoconcorp.com
Message 13 of 13
That was it. I didn't have the 'show tangent edges' box
checked. All the lines appear now.
Thanks for all the help.
Gary
