Yesterday I was creating Arcs with the line tool. Today I can't. Last night WIndows 7 did an automatic update, and that's the only change that has been made to my system. I've played around with the constraint and even the display settings, to no avail. I am using a Dell M6400 laptop with no peripherals.
Another change I noticed- it seems the orgin point and end points used to be green when selected, but now they are yellow.
Any advice would be greatly appreciated.
Solved by JDMather. Go to Solution.
Post a screen shot of your Constraint Options and Constraint Persistence.
Could this be related?
http://forums.autodesk.com/t5/Autodesk-Inventor/Problem-after-NET-updates/m-p/4330346#U4330346 (User had an issue with recent NVIDIA driver update crashing Inventor)
@rockscout wrote:....: currently I have none infered
And therefore your problem. Coincident Constraint must be inferred.
Set yours like mine (and you should state what version of Inventor you are using).
There is no reason to turn them off (you can hold Ctrl key to temporarily suspend autoconstraints - I have had to do that, oh maybe, twice in past 10 years).
That fixes it. Thank you very much. This is only my second day on the program, and a little help goes a long way.
For anyone coming accross this post in the future I'm using Inventor 2014.
@rockscout wrote:....This is only my second day on the program, and a little help goes a long way.
http://home.pct.edu/~jmather/skillsusa%20university.pdf
