Does anyone have any answers to how to move the direction of the lighting in an idw.
I have tried modifing the lighting.xml document but this still has no effect. If it is controlled by the default lighting settings, I tried to modify all the releavent values to no luck I also did this with the two lights positilonal values.
I then tried deleting all the information from the xml file keeping just <lighting version="2"></lighting> and Inventor still loaded the idw's happily so I am not sure if it is looking at this file for ligthing information within idws
Has anyone had any results with this issue.
Richard
@jcneal wrote:
is there any hotfix of this issue in autodesk inventor 2015? thanks
We can't tell you as 2015 is still in beta and users are required to adhere to an NDA.
Not to mention that a hotfix is for bugs.. not adding new features/requests.
Is there a specific problem you are having? You can modify the lighting in an IDW to some extent and disable gradients/reflections,etc...
http://inventortrenches.blogspot.com/2011/02/disable-reflections-and-gradients-in.html
This just today became an issue for me. Looks like it still has the same issue, even in Inventor 2014. Wanted it shaded for an iso view. I just projected an iso from the other direction, but still. I couldn't figure out why it wouldn't shade like the model had it.
In the "good old days" the lighting was saved in the view representations and changing the lighting in the view representation used by a drawing view would update the lighting of that drawing view.
In Inventor 2010 when the realistic shading was introduced this changed. Now the drawing views get the "Default" lighting style as it was saved in the Style Library when the drawing was created. (Note that the default lighting style of the model templates installed with inventor is not "Default" but "Two Lights".)
So to change the lighting of a drawing view, change the "Default" lighting style of a model file and save it to your Style Library and create a new drawing. Copy the drawing view from the old drawing and paste it into the new one and you have adjusted the lighting of your view.
This behavior means that all shaded views of a drawing will get the same lighting style.
Since we have Inventor Studio, 3ds max design, Showcase and so on to produce realistic renderings I think that the ability to more easily adjust the lighting of shaded drawing views like pre Inventor 2010 is much more useful than the realistic shading of the model.
