Hi, Andreas,
Authorize on your laptop, and start using Inventor again.
You will be able to export to your workstation, but you may still have to
fix the [16.1.7] problem there. Are you sure that you have read/write
access to the directory "C:\C_DILLA"? Have you turned off any antivirus
program?
It's not a problem that it didn't ask to reboot; this is only done if
necessary. To check the installation, just start the Portable License
Utility. If it doesn't give any errors when started, then it's OK. Excuse
me, what do you mean by "MD"?
Before you export the license, make sure that the Machine ID Code hasn't
changed on either PC, because of the reformat.
--Cy--
"Andreas Unger" wrote in message
news:3F7D4D9B.CB1CDD6C@computer.org...
> Cy Shuster schrieb:
> > Now, you must fix your installation problem before you can get a new
auth
> > code (which you will still need). Make sure you are logged in as the
local
> > administrator of this PC (not a network domain) for all steps.
> everything re-installed, e.g. on the workstation complete uninstall
> to inventor and C-Dilla,
> afterwards re-installing inventor,
> patch to C-Dilla (and additionally patch to the admlres.dll, required
> for the German version).
> for the laptop formating disk, setting up OS, same installation
> procedure
> as above.
> (pure deinstall to C-Dilla + patch was done first, but didn't succed)
> Always with reboots, between any two steps.
> Result, workstation gives the message box, "an previos installation
> was found, you have to re-authorize."
> When saying okay, an other error-box is shown: "unexpected error
> in licencing system; error code [16.1.7]"
> When sayign okay, one more error box, saying: "go to dealer" and
> than the inventor stops.
> Result on the laptop: I've got a new auth-code (16 Bytes)
> The only difference I realized, was that when installing the
> C-Dilla patch, the last action on the laptop was: "do you
> want to reboot". This step did not occur at the workstation.
> So I could imagen, that this installation did not really succed,
> because the MD is still unsing C-Dilla at this workstation?
> (Because of the software running on top of the MD, I don't want
> to takt any risk to loose or having to reinstall the MD.)
> I could now send the auth-code to adesk, authorize the laptop
> and either use the inventor only on the laptop or I could try
> to export the lincence to the workstation, hoping that there
> is no new trouble.
> What seems to be the better idea?
> Thanks for any comments,
> Andreas
> unger @ computer.org
