Inventor Forum
Large deformation
9 REPLIES 9
Message 1 of 10
4258 Views, 9 Replies
Large deformation
Hello and have a nice day,
I'm currently working on FEA for pressure part. After simulate that part. Autodesk program give me this warning :-
and the value of von mises stress is too high. Can someone help me with this problem?
9 REPLIES 9
Message 2 of 10
JDMather
Attach your assembly here.
Message 3 of 10
admaiora
in reply to: JDMather
Your forces are probably to big compared with your model, causing a great deformation and so ..no good results.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 4 of 10
CCarreiras
Hi!!!
This is due the force applied in the model: is to high for the structure.
Try to increase thickness of the wall, insert some reinforcements, etc.
Also, check if the material was well chosen. Check the force magnitude and unit  applied, make sure is correct.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 5 of 10
Another thing to take note of, if your assembly or part is not properly constrained (ie. fixed or pined) causing the part to move or spin endlessly...
Message 6 of 10
salasriveros
I appreciate you can help me with this problem.
Regards
Robert Salas
Peru
Message 7 of 10
JDMather
in reply to: salasriveros
An assembly must include parts.
Message 8 of 10
salasriveros
Message 9 of 10
salasriveros
Message 10 of 10
JDMather
It would be best to test these parts one at a time rather than as an assembly.
Which part are you most concerned about?
But most importantly - where did you get this number for Youngs Modulus?
Compare to Steel.
100 Pa vs 210000000000 Pa?
