Hi Inventor Gurus
I was hoping to print ‘A custom’ (2400*1200mm), on any A4 printer,
but the lines of my PDF print out thin.
When using a Standard A4 as a plot page the print thickness works well.
Am i asking too much wanting a Large Paper Size to print out adequately on A4.
Can it be done easily?
Can i include Layers & line weights in Object Defaults so as to have a one large and one small page size setting?
Thanks MatB
If you already have the line weights and layers setup in your templates for a specific size, it is only natural that they are going to come out different if you change the printout size. I would create that size that you need to print out the pdf and make sure the line weights and layers are set the way you need them to be.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
