Inventor Forum
Kent's Multi Insert & Fix VBA
11 REPLIES 11
Message 1 of 12
Alex123
603 Views, 11 Replies
I just used Kent Keller's Multi Insert & Fix VBA and it works great. My question is how does it work? I noticed it grounded the parts but there were no constraints used. When I do it "manually", I use flush constraints to ground them to their origins. How does the utility know how to ground them without constraints? Curious.
11 REPLIES 11
Message 2 of 12
in reply to: Alex123
RMB Ground (which makes the push-pin)
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"Alex123" wrote in message
news:f1224c5.-1@WebX.maYIadrTaRb...
Message 3 of 12
Alex123
I guess I didn't explain myself well enough. I know how to ground it, how does it position it correctly in relationship to the origin without constraints?
Message 4 of 12
If you go to properties of any part occurence in an assy you see under
occurence tab a series of numbers for x, y & z offsets from origin.
Kents routine simply sets these at 0
- Drew
news:f1224c5.1@WebX.maYIadrTaRb...
constraints?
Message 5 of 12
Actually if I remember right it is even simpler than that. When you insert
a part with VBA it defaults to 0 and if you wanted it anywhere else you
would have to add code to move it.
Something I probably don't mention enough about this routine is that It came
about from me bugging Drew to come up with a idea for a useful program.
This program was something he was going to try to learn some VBA with, but
he instead told me about it and let me give it a shot.
So the real credit for the program belongs to Drew, cause without the idea I
never would have done it. 8^)
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
"Drew Fulford" wrote in message
news:B144B64943052C3AEFA18553A0A286EE@in.WebX.maYIadrTaRb...
> - Drew
Message 6 of 12
Blush 😉
"Kent Keller" wrote in message
news:B39C64D2E24CE0EBD0C38894FF14D063@in.WebX.maYIadrTaRb...
insert
came
I
> Kent Keller
> > - Drew
Message 7 of 12
Alex123
Thanks guys. Now I learned an easy way to position parts without using constraints. I knew there had to be an easier way than the way I was doing it.
Message 8 of 12
You might also want to look at Murray Smith's program
http://www.cbliss.com/inventor/iCode/Positioner.zip
> doing it.
Message 9 of 12
"Now I learned an easy way to position parts without using
constraints."
Unless you are doing skeletal modeling that is a
dark and dangerous road you are headed down...
____________________
Sean Dotson
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak...
it.
Message 10 of 12
I have used Kent’s routine before in IV5.
Now we have upgraded to IV6 and I have lost the routine.
Could someone please tell me where to find it and does it work in IV6?
Kind regards
Flemming Madsen
LIC Engineering A/S
DK Denmark
Message 11 of 12
Just follow the link in my sig and then click on the iCode link
Kent Keller
"frm" wrote in message news:f1224c5.8@WebX.maYIadrTaRb...
> I have used Kent's routine before in IV5.
> Kind regards
> Flemming Madsen
> LIC Engineering A/S
> DK Denmark
Message 12 of 12
Thank You Kent
Best regards
Flemming
